T56 Wiring help
T56 Wiring help
Ok heres the situation im in. I have a 89 Camaro with a T56 behind a Small block carb motor. I need to know how to wire up the VSS to my autometer gauge. Also should I wire up the reverse lock out as well?? Not sure if I need it really.
If anyone can help me out let me know. Thanks
I know its not a digital or mechanical one at all. This is the one I have
http://www.autometer.com/cat_gaugede...id=2789&sid=15
I need help on how the VSS wire would be run. The pigtail has 2 wires coming out of it but not sure what they connect to at all.
Same with the reverse lock out. 2 wires come out of the pigtail and have no clue what they would connect to.
Plaease let me know if you or anyone can help me out so I can get this done
