I broke my toy
I broke my toy
So on my way home from South Haven Sunday afternoon I got to Kalamazoo and every time I let off the gas I would hear thunk thunk thunk, sounded like my drive shaft hitting something, since i was only about 10 miles from home I just drove it the rest of the way home, Last night I jacked up the car to see what was going on and this is what I saw
So I need some suggestions on fixing this and beefing it up. I would like to get a set of weld on sub frame connectors and LCA relocation brackets while im under there, Is there any one that makes sub frame connects that reinforce that mount?
for some reason i cant see the pics you posted. what you described sounds like what happened to me a while back. here is a link to my fix.
http://www.firebirdnation.com/forums..._1#entry626246
My problem is different I have a spohn adjustable torque ARM that is mounted to body mounts of that thin metal bracket and the 4 tack wells that hold the mount to the body broke off so every time I let off the gas that mount knocks on the body
