Gen 5 Camaro Power-Adder Tech - 65 lbs Injectors
SuperSlowLS3
08-03-2011, 11:23 AM
What Injectors is everyone on a LS3 6-8psi?
Estes
08-04-2011, 04:00 AM
I've got Siemens 60lb injectors with a dual fuel tank setup and it works perfect. I've heard of guys going to 10 psi on the same setup as mine. I'm sure you can go even higher.
I did 60's also, but the vendor gave a rail kit, that wasnt even close. It became very obvious even after al his smack talk, that he had never worked on a new ls3. I thought it was pretty funny actually.
I couldnt get short 60's at the time. If you use the talls, you have to space up the rail alllooong ways......which inturn requires losing the engine cover. I cant figure out why anyone likes the engine cover anyways. All it does is ad weight, and keep heat in....hmm good idea huh.
Estes
08-05-2011, 12:55 AM
I agree. First thing I did was take that thing off. I want to see motor, not a cheezy cover. I had the talls also. Took a little effort, but there in there like swimwear.
SuperSlowLS3
08-05-2011, 06:16 AM
Ive already got the cover off,Im gonna do meth injection and am already running a nice cam..,shimming the fuel rails doesnt bother me.so u guys are pretty sure the 60s Will handle 650 rwhp?
SuperSlowLS3
08-05-2011, 06:18 AM
you guys got any video of your cars out on the street?
Estes
08-05-2011, 10:26 PM
No sorry man I don't. I just got it up and running the last time I was home. I work out of country so I don't have a lot of time to do things. I'm Pretty sure your good with the 60's but can never go wrong with bigger ones. If your looking to keep going then I would go as big as you can. I'm sure you can go so big that it wouldn't work right on your setup, but I don't know what the threshold is. I don't even know if that's an accurate statement, LOL
I dont either, Its not my car either lol. I built a 2010 turbo car for a friend. I did a 76mm, 50 mm gatefmic with a devils own water meth.
650 should be no problem.
SuperSlowLS3
08-10-2011, 07:35 AM
It becomes a tuning nightmare if you go to big on the injectors.
Ryne @ CMS
10-25-2011, 08:27 AM
FIC 65 lb injectors, direct swap no modifications to the rails or wiring, tune out great
BLACK MAMBA10
10-27-2011, 08:57 PM
im running 65's and made 745rwhp with just a BAP also.
