speedfreak2685
08-03-2011, 07:56 PM
I have a black M6 z28 ss clone. I have thought about selling it. Just curios what it is worth. I bought it completely stock about 3.5 years ago from a older lady and the every single part on the car has less than 7000 miles on it. it has"
84000 miles on it.
black paint 8/10
tan leather interior 8/10
factory GM SS hood and Spoiler
Chrome ZR1's 17x9.5 front, 17x11 rear
275's up front 315 drag radials in the rear
Trans:
6 speed just rebuilt by Tick Performance lever 2
tick master cylendar
new spec 3+ and steel flywheel
B&M short shifter
Motor:
MS4 cam
Hardened pushrods
double valve springs and new valve seals
Melling high volume oil pump
Mods:
FTP 98mm lid
GM 85mm MAF
Ported fast 90 with Nick Williams TB
Truck Coil swap relocated to the firewall
TSP 1 7/8" headers
TSP true Dual Exhaust
SLP underdrive pully
catch can
Rearend:
Moser 9 inch, 31 spline axles, truetrac, aluminum center section, 4.11 gears
welded in lower control arm relocation brackets, arp studs
UMI adjustable torque arm
UMI torqu arm relocation bracket
Sphoon 1" rear sway bar
Sphoon lower control arms
welded in subframe connectors
Drilled/Slotted rotors all around
Lowered with Eibach sportlines
Billit grill with SS emblem
Car made 415/384 through 10 bolt
I just want a something different I recon. So what do you think it is worth? I know I will not get near close to what I have in it but time to move on.
84000 miles on it.
black paint 8/10
Trans:
B&M short shifter
Motor:
MS4 cam
Hardened pushrods
Mods:
FTP 98mm lid
GM 85mm MAF
TSP 1 7/8" headers
catch can
Rearend:
