Pop from somewhere
Pop from somewhere
Crossed railroad tracks going less than 2nph. Loud pop and clank sound. Ever since I can hear my car clanking. Checked basic suspension components without removing wheels. Nothing loose, busted etc. Only hear it at take off or while crossing rough road, bumps etc. HELP! Going to lower the car tomorrow, will update with any new info ASAP.
Thank the us military for the ability to shorten sentences and still make sense. Lmao
LS1Tech Premium Sponsor
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Is your car stock suspension wise?
Seems like it would be difficult to break something going a whole 2mph.
I have a noise that I have been trying to figure out for a long time and still haven't got it figured out. Here are some ideas, although they are more for front pops not just something that would break from going over a railroad.
Ball joints can make a popping noise. How many miles are on the car?
If you had replaced the shocks, if the top nut isn't torqued down enough you can get a pop noise.
Check the sway bar end links. If they are poly it is possible to crack them, but pretty rare and more due to overtightening. If you have rubber make sure they aren't worn out.
Since you are lowering, when you get the wheel off double check the rest of the front suspension like the bushings for the control arms and the tie rods. Also floppy brake calipers can pop, and if your brake pad clips are screwed up you can get noise from pads moving around. Might as well check the hub / bearing, but I wouldn't think it would make the sound you are describing.
