LSX block. which clevite cam bearings/ bearing install tool?
Old 08-03-2011, 10:48 PM
mattz06's Avatar
Default LSX block. which clevite cam bearings/ bearing install tool?
replacing my lsx block cam bearings, they all read ch-p-10 except one has no p. are all 5 cam bearings the same?
which clevite part #? same cam bearings as an LS1?
where can I get cam bearing install tool? ( I know a machine shop can install them but prefer to do it myself)
Old 08-04-2011, 12:59 AM
kevin kuether's Avatar
All the cam bearing are the same size. Not sure of the number off hand though.
Old 08-04-2011, 06:25 PM
JS01's Avatar
I believe they are all CH-10-3
Old 08-09-2011, 07:11 PM
CAMSTER's Avatar
Default Cam bearings..
I just had mine install and bearings are the same size, just a word of caution some came 2-3 thous too large, where by after installation the interior became too tight and the machine shop had to manually adjust them.
Old 08-09-2011, 08:47 PM
KCS
Moderator
KCS's Avatar
Bingo.
Old 08-09-2011, 09:18 PM
mattz06's Avatar
yep got durabond chp-10 which has 3 different sizes, all incorrect other than chp10-3, they're all the same in a lsx block. chp10-3 ordering 4 more sets from summit to pull out the 4 more chp10-3's I need cant buy em seperately
Old 08-10-2011, 07:51 PM
KCS
Moderator
KCS's Avatar
Who said you couldn't buy them separately? I know you used to be able to, that's weird if Durabond changed that.
Old 08-10-2011, 11:02 PM
mattz06's Avatar
youre right, you can buy them seperately from summit special order for $27 each or a whole set for the same price and pull out the chp10-3 and buy 5 sets!
Old 08-11-2011, 01:43 PM
KCS
Moderator
KCS's Avatar
Have you called Durabond?
Old 10-31-2012, 03:44 PM
Teamscss.com's Avatar
Just got off the phone with Mahle-Clevite engineer.
LSX GM bowtie blocks take the following cam bearings:
SH1816S ( shortly will be superceeded by SH2142S )
CrossRef to GM p/n 12453169 ( superceeded by 19167218 ) or Durobond p/n GM9
Quick Reply: LSX block. which clevite cam bearings/ bearing install tool?
