HID Issue
HID Issue
Hey guys, I installed the ddm slim ballast 55 watt 6k kit in both my low beams and my fog lights in my 97 Z. For a while I realized that sometimes my driverside headlight wouldnt turn on, But most times it would. Recently it has always been out. What i dont get is that when i first turn the key, or turn the lights on, you will see it light up for a second but immediately turn back off. I checked all the plug ins and all seemed secure. If i have the lights on and unplug it and plug it back in it will do the same thing. Light up for a second then shut off. Any idea what causes this??
I didnt ask if I should have them on or not. If you didnt know, the lighting in 93-97 f-bodies is horrible. This is one of the only solutions for it. I have mine aimed down and they arent any worse than all the new cars with hid's in them.
Formally Simplɘ Jack
Imo 55w is too high, I have the 35w kit 6000k from Xentecs and they are PERFECT. Other then that, the fact that you also have the fogs HIDs you will need a relay harness for the battery cause there's too much power going on that the factory harnesses can't handle all of it especially if you have 55w's. I don't have HID fogs just to avoid the relay harness but that's just me, so I just put Nokya artic white bulbs.
Thanks for the input. This is exactly what I was looking for
Ya I was going to go w/ DDMs but just went w/ Xentecs cause they were cheaper but as for the relay harness, I'm new w/ all the HID talk but I believe its a relay harness per set but i think you just need one, get it w/ the fogs. I made a thread about HIDs and all the members were real helpful w/ the information needed about HIDs, here you go and good luck.....
https://ls1tech.com/forums/appearanc...te-w-pics.html
Here is where I got my HID kit from. A little pricier than the other ones, but well worth it. All the parts were in there so it was plug and play.
http://www.theretrofitsource.com/pro...roducts_id=170
So does anybody know if I need one or two relay harnesses?? I have two 55 watt kits. I am hoping to order them today. If its just one, I will figure out which one to put it on
The harness is just so you don't put a strain on the factory wiring. I am running the 55w w/harness from DDM and have no issues. If I was going to get HID fogs also then I would run another harness for them. Cheap insurance IMO. You may only need a 35w for the fogs should work just fine.
From DDM's site:
"Use the relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably.
Recommended for all 55W HID installations but most American and European cars work at 35W/55W without the harness. The harness is definitely recommended for Quad's and other ATVs or when running multiple HID installations. This harness is a fused relay isolation harness capable of supplying 40A at 12vdc."
The reason you need the relay is because the HID ballast requires a very high initial current to light the bulbs, but the steady-state current once they are on is no higher than that of the OEM lamps. The relay allows 12V to come straight from the battery instead of through the small gauge wiring of the lighting harness.
Long story short, if you're running 55W in EITHER your low beams OR your fogs, you will need a relay harness for that kit. If you're running 55W on BOTH, you will need the relay harness for both, because otherwise your stock wiring will not be able to supply enough current to ignite the bulbs.
