Sponsor Sales & Specials - Drift Innovation HD Stealth 170 Camera Clearance
Fast Toys Performance Parts
08-04-2011, 01:17 PM
I have some Drift Innovation HD Stealth 170 Cameras on CLEARANCE. These are all brand new.
The Drift camera is the main competitor to the GoPro HD but has some really great advantages:
1. Remote control to start/stop recording.
2. Built in screen to aim/view camera
3. Rotating lens allows you to record right image right side up when camera is mounted in an odd position
4. Ability to use standard camera mounts
5. Ability to use external microphone (no more annoying wind noise)
PRICING
HD170 Camera with standard accessories: $ 299.00 shipped
Add long life battery : 24.00
Add Case: 24.00
Add Rear Cover: 13.00
Add Suction Cup Mount: 25.00
Add lens protector with glass lens: 45.00
Add lents protector with plastic lens: 34.00
Add long life battery kit with wall and car charger: 40.00
A full list of features is below:
Drift Innovation Stealth HD170 Camera
The Drift HD170 is the worlds first sports action camera which films in full 1080p HD and has a playback screen and remote control. The Drift HD170 blows the competition away with features that enthusiasts request the most. This rugged water resistant camera is the first camera that gives people what they want from an Action Camera:
•Full HD for creating crystal clear footage
•A playback screen for lining up shots and the ability to play back the footage right away
•A remote control to enable you to film what you want to record, not the boring stuff in between
•Easy to use mounts so you can use it whenever you want and mount it anywhere your imagination allows you. The shape of the camera and the mounts it comes with make it the easiest camera out there to use If that isn't enough the camera also has the following :
•A rotating lens so you can mount the camera at any angle and any position to get that shot you are looking for
•It can take photos, put it in the photo burst mode and you can take pictures every few seconds for as long as your memory card lasts. If you don′t get a decent photo then you need to do something else or give the camera to someone else who can really use it
•You can pair the remote control to your camera, chances are your mates will have the same camera, no turning off their camera just before they hit the tree
•A zoom function so you can get even closer to the action or your friend in front
•An optional external microphone (sold as an accessory), so no more listening to wind noise, great for in-car filming
•Night mode so you can record in darker and duskier conditions
Features:
•Maximum Video Resolution: 1080p High Definition
•SD Memory Capacity: up to 32GB
•25 / 30 / 50 / 60fps in 720p or 25 / 30fps in 1080p
•Still Photo: 5 megapixel with Photoburst Mode
•Digital Zoom: Digital x4 (in 720p/30/60fps & WVGA mode)
•Lens Angle: 170° Fully Rotatable Wide Angle Lens
•LCD Screen: 1.5″ Colour TFT
•Water Resistant
•Remote Control: Wireless RF (5m range) Hands Free Video and Photo
•Mounts: Multiple Mounting Design
•Audio: Built-in Microphone & Speaker
•Menus: User Friendly Control Panel in 7 Languages
Technical Specifications
•Sensor type: CMOS
•Water Resistant
•Video resolution: 1080p, 720p & WVGA
•Video format: H.264
•File format: .MOV
•Video format: 16:9
•Lens Rotation: 300°
•Recording Angles: 127° in 1080p, 170° in 720p & WVGA
•White balance: Auto
•Exposure: Auto / Manual (advanced users)
•Zoom: Digital x4 (in 720p/30/60fps & WVGA mode)
•Remote range: 10 ft. range
•Built-in Microphone
•Inputs: Optional External Microphone
•AV Output: HDTV out (cable included)
•Battery: 1110mAh rechargeable lithium-ion/ Optional 1700 mAh Li-ion rechargeable.
•Power-Save option saves batteries by powering down the screen
•Built-in memory: 32 MB
•SD memory capacity: Supports memory cards up to 32 GB
•Photo resolution: 5 Megapixel
•LCD screen: 1.5″ colour TFT
•Lens focal range: 0.5m to infinity
•Dimensions: Camera – 133 (L) x 50 (D) x 33 (W) mm / Remote Control 52 (L) x 40 (W) x 13 (D) mm
•Power: Camera – DC 3.7V / Remote control: DC 3C, 1x CR2032 battery (included)
•RF: Receiver (Camera): 433.92MHz ISM band / Transmitter (Remote): 433.92MHz ISM band
•Weight: Camera – 138g / Remote control – 19g
•Operating Systems: Compatible with Windows 7, XP & Vista; Mac OS 10.2
Call us to order at 877-955-4896 as this is not currently listed on our web site!
