My lt1 overheats fast
Old 08-04-2011, 11:37 PM
gld7's Avatar
Default My lt1 overheats fast
My 1994 z28 heats up after a trip around the block Im using the pcm and motorfrom my 97.Did my timing change or what?
Old 08-05-2011, 12:03 AM
IronOutlaw's Avatar
You probably have air in the system. Rum it a while, then shut it off and bleed it using the two bleeders coming off the waterpump. These cars are a pain to bleed.
Old 08-05-2011, 06:13 AM
qc97z's Avatar
^ This. Or...
The thermostat is stuck closed.
You have little to no coolant in the system.
Check out SHBOX.com. It has a lot of useful information, for noobs and veterans.
Old 08-05-2011, 07:54 AM
BowtieGirlZ28's Avatar
How hot does it get? Does the coolant push out of the reservoir...are your fans Turning on? I would definitely start with the t-stat and air like they said....
Old 08-05-2011, 01:40 PM
LT1FirebirdSLP's Avatar
1) Air in system.
2) Low coolant level.
3) Fans not turning on
4) Stuck thermostat in closed position.
5) Broken water pump.
That's my $0.05
Old 08-05-2011, 08:56 PM
gld7's Avatar
Default Overheating Problem
My fans never turn on, and I only see one bleeding screw. the water has risen in the overflow. bleed I called myself bleeding the thing Iguess it didnt.My guage is not working at all Ive got to check it out too
Old 08-06-2011, 10:03 AM
Okay, it's been a while but i have replaced the sending unit on mine...sometimes when the motor gets to hot it kills the sensor Mine is on the right side of the block ...it screws right in, there is a little wire assembly connector thing that you take off first...you will need to put something under the block to catch any fluid that leaks out when you take the sending unit out....
Attached Thumbnails My lt1 overheats fast-photo-0265.jpg   My lt1 overheats fast-photo-0265-2-.jpg
Old 08-06-2011, 10:06 AM
I would also check the relay for the fans....There should be two bleeder valves, unless you bypassed the heater core or something...I found this pic on the internet...can you see the valve coming off of the housing for the t-stat on top of the water pump? The other one is right on top of the part of the assembly with the three compressed hoses on it...Hope this helps!!
Attached Thumbnails My lt1 overheats fast-800px-1993chevroletcamaroz28-003.jpg
Old 08-07-2011, 09:44 PM
qc97z's Avatar
There are 2 bleeders. One on the T-stat housing, one on a heater hose.
The sensor that controls the fan is NOT on the side of the HEAD . It's on the front of the water pump, on the bottom right side. The sensor on the head is for the temp gage only.
Old 08-07-2011, 10:00 PM
Yeah, he said the gauge wasn't working, i probably called it the wrong thing, but i showed him the right part to replace if the temp gauge is not working
Quick Reply: My lt1 overheats fast
