LMP (sealy) saturday!?!?
I will be there to brake my 13.xx ad go for a 12.99xx.lol
I hope to see ya'll out there!!! aslo if you are going and have a set of extra rimed slicks that would help too. going to be playing with my hptunners to put a lil timing into it to get off the line a little better. should have a couple friends there with me. I called out a LS2 gto and a mustang at work so.......
I got a couple buddies from work that are going with us also so we gotta get you running right. One has a cammed 2000 SS and the other has a 2009 SRT8 Charger. Hopefully my car wont be limping to much longer.
Look forward to seeing all you guys run.
Well twist my arm! **** it, i'll be there regardless then and use the track to get some good WOT logs so I can get this ironed out! What time are ya'll thinking of heading out there? I know I still have to tighten up the race's on my roto-joints, install new rear end links, and grease everything up - after I get off work tomorrow. PLUS, I plan on hitting up Washington afterwards and trying to go see that chick I showed you the other day
.2 slower than my last trip(3 or so weeks ago)!!! with better traction than last time..... slower traps and slower 60' times.... SLOWER!!! playing with settings set me back... learning curve...
Don't feel bad, last time I went out, September 25th 2010, the first pass I ran like a 12.6719 @ 104.14 MPH. They didn't have the checkered flags marking the 1/4 and the back lights weren't on yet. I was doing around 120 MPH and figured I had passed the 1/4 and let off. I was surprised to find out I had let off before the end of the line. The next pass I broke the driveshaft on the launch.
This past Saturday, I got in 3 passes before I decided to give up. The first pass, I ran a measly 13.0561 @ 110.70. I'm getting high RPM (4K-6K) misfire and/or detonation. This is through all gears. The second pass, I ran a better but still worse than last September, 12.7898 @ 111.30. The last pass it was popping so bad in 3rd I let off and ran a 13.0621 @ 108.46. My IAT's were in the 130-140*F range at the start of the passes. I am either running out of fuel or the oil cooler I put in front of the AC condenser is heating the incoming air too much and causing detonation.
What time were you there? I ran from around 7:30 til 8:45 and headed out.
Haha, you should of said something! So, how bad was my car popping? Any flames out the pipes? There was a lot of fuel being dumped out the tail pipes in the higher RPM range!
Thats the only flame I saw...bwahhhahahahahaha
Hey yo, I think I got it fixed, or 99% of it anyway. I moved the oil cooler on Saturday and put a fan on it yesterday. That and changing plugs and wires last week and I am 99% sure it is good to go. If so, we are going back this Saturday, the 20th! Just later in the evening...
well i never know whos who and... yes looked good a lil extra unburnt fuel... yes... i just go my lc1 so my tuning begins!!!! got to work till 10ish on sat so itll be next time... that'll give me some time to have 2 rough tunes ready..... i hope!!!!
Anyone going out this Saturday? I have some buddies coming out (couple ram srt-10s, a few TBSSs, twin turbo 350Z, ZR1, some SRT8s, and a few mustangs) I know it will be pretty hot but should be a good time.
