fuel pressure regulator ?
I am trying to peice together a stand alone fuel system for a direct port kit. I do not have 800 bucks to buy one already made. So im throwing one together. My ? is when looking for a fuel pressure regulator what PSI should i look for? 4.5-9/5-10/5-12 ect ect. And what should it be set at for a 200 shot? Thanks for your help?
Here is a ruff sketch what i am assuming how a stand alone is plumbed. The fuel cell i am useing is a 3 gal aluminum. It has a -8 an outlet,-8 an return,and a -8 an vent. I am assuming i do not use the return line correct? Also on the other side of the fuel regulator is where i switch over to a -6 an fitting to hook into nitrous solenoid.
No return is called a dead headed system...and will be fine.
As for your fuel pressure regulator, 4.5-9 will be fine (lower pressure uses bigger jet)
One thing I would add is a low fuel pressure cut-off switch (incase the cell goes empty or the pump sucks air)...basic safety
Guest
Posts: n/a
Thanks btw for the referral!
No problem Graham...I'm still learning on this stuff myself and don't want to give someone bad advice and toast their motor....bad enuff if I do my own.
