Just got a 2002 WS6, have questions
Well, first off my heads are stamped 853. From what I understand they don't belong on my car, do they? What are they from?
Where can I locate the vin on my block??
How can you tell if you have an ls6 intake?
Also, my transmission has a "wine" guy I got the car from said it has always done that. But idk if I should be scared?
Last but not least, where can I find one of those front bumper license plate covers that has the firebird on it? Mine is missing. Thanks guys
Block numbers are hard to read, do a search for methods. Easiest is while on a lift.. if not mirror can be used.
Does the intake have a hose going into the top on the front middle? What is the part number?
The whine is probably coming from the rear. Are you sure its the trans? Ten bolts are notorious for gear whine after a few hard launches.
Search the classified section in here and ebay.
Can't look right now, so why would those heads be on this car?
http://m232.photobucket.com/albumvie..._0468.jpg.html
And yes it is def the trans
LS1Tech Administrator
Received 1,487 Likes
853s are not from a '98. 1998 received 806 heads and perimeter bolt valve covers.
853 heads will have center bolt valve covers, and were used on '99 and most '00 cars (some very late '00 cars received 241s, just like the '01-'02 cars).
It also appears that you have an LS1 intake, with a visible EGR tube. This is not correct for a '02 car either. Someone may have swapped in an entire engine from a '99-'00 car.
LOL!
BUMP! I want to see how this turns out.
The 2001 and 2002 LS1's should come with an LS6 intake, but like above posted, may be an engine swap from an older F-body.
Great VIN decoder site to see what your car came with from the factory.
http://www.compnine.com/vid.php
The RPO "LS1" is all you will see in terms of an engine specific code, whether it's a '98 or an '02 (assuming V8 car). Things like camshaft profile changes, head casting numbers, PCV system changes, LS6 intake, exhaust manifold changes, injector size changes, etc., are not shown by RPOs.
