Fuel Tank Venting
Old 08-07-2011, 01:52 PM
leadfoot4's Avatar
Default Fuel Tank Venting
My fuel pump was getting really noisy a couple of months ago (96 Z-28), so I had it replaced. Since then, I noticed that when removing the gas cap to refuel, I no longer get the "whoosh" from the air entering the tank.
I looked underneath the car, and all of the lines appear to be hooked up, and I replaced the gas cap, to no avail. I disconnected the purge line at the engine, and sent compressed air back through the system (4-5 lbs. of pressure), and the only place the air was exiting, was the "non-connected to anything, vent line" at the EVAP cannister.
I don't get any codes, the car runs well, but I'm concerned that something isn't right, since there is a change in the car's behavior. Anybody have any ideas?
TIA!
Old 08-07-2011, 03:51 PM
FormulaJoe's Avatar
So you're concerned about the "whoosh" going away? I'd say that noise when the gas caps opened is a bad thing seeing as that vent tube is supposed to keep pressure out of the tank itself? No noise when I go to fill the tank and take the gas cap off.
Old 08-07-2011, 04:07 PM
leadfoot4's Avatar
Joe, my concern is this...If I understand the evap emmisions system correctly, there's some minimal amount of engine vacuum in the system that draws the vapors from the tank, through the purge canister, and draws them into the engine, where they're burned.
When you shut off the engine, the residual vacuum holds the vapors in the canister. The "whoosh" you should hear is the release of this vacuum. Also, whenever I now shut down the car, I smell fuel vapors. I didn't before, and do now....
Old 08-07-2011, 04:41 PM
Sc0tt30's Avatar
Same thing happens to me since i deleted the evap line from the fuel system. I still have a line coming off the fuel tank put it just stops at the rear of the car. I still needed the vent.
Quick Reply: Fuel Tank Venting
