500Hp goal to the wheels Need Help!!!
Old 08-07-2011, 07:11 PM
04z06dragginballs's Avatar
Default 500Hp goal to the wheels Need Help!!!
wanting to reach 500 hp goal.. what do you suggest as far as mods to reaching this goal?
its a 04 z06 i have mounted LG 1 3/4 headers Kooks x pipe no cats slp loudmouth catback and a vararam CAI.. was thinkin of going with the ms4 cam and the trick flow 215 heads as the next mod?
Old 08-07-2011, 07:22 PM
ULTIMATEORANGESS's Avatar
Smile
you wont get that on a mustang dyno thats for sure. might even be tough on a dynojet with those mods.
Old 08-07-2011, 08:13 PM
any suggestions on other suporting mods to reach my goal?
Old 08-07-2011, 08:15 PM
Smile
nitrous.
Old 08-07-2011, 08:17 PM
and the rear end will hold up?
Old 08-07-2011, 08:22 PM
Smile
not familiar with z06 rear end strength. i would think youd want to minimize wheelhop with an IRS though.
Old 08-08-2011, 02:47 PM
Full-Force's Avatar
Ported Fast intake and TB, good heads, big cam, electric water pump, pulley, good tune, and maybe bigger headers.
Old 08-08-2011, 06:59 PM
brianw401's Avatar
Make sure you mill the heads & flycut your pistons for max compression. Also, get a hold of Tony Mamo & have him port you a fast 102. With a 102mm TB & mass air, it is possible. I'm at over 480whp with a similar combo w/o the ported fast. Also, check out Pat G's 500whp recipe thread. It's the best thread on here! Good luck!
Old 08-08-2011, 07:59 PM
bayer-z28's Avatar
You got your answer in the other thread you posted about this. 500rw out of a 346 isn't easy or cheap.
https://ls1tech.com/forums/generatio...heads-cam.html
Old 08-09-2011, 06:11 AM
miami993c297's Avatar
Click on the link below:
https://ls1tech.com/forums/dynamomet...1rwhp-fti.html
Christian
