what do u guys think of the TR224 LSA114 for nitrous
Restricted User
actually that cam sucks for juice. The pattern is not maximized for spray. Will it work, sure, so will a stock cam, a reverse split or traditional split. But the heavy exhaust is a little better for spray with a wide LSA. Less overlap more cylinder pressure and that gives the power. But, it works obviously.
good-luck
Charlie
good-luck
Charlie
Restricted User
Humm. Sounds like mixed reviews.
I guess one way to research this is to see who has had the cam, what they ran compared to pre- or post cam and compare to new setup. Me, well. I ran better with that cam on spray than I did all stock and spray, lets say it was around .4 tenths better than a stock 2000Z28 with same size shot, 150 for the record. Now with the TSP cam I have run the same ET better trap with a smaller shot. The cam is bigger, and changed a few things so, cant judge by my setup.
Over stock, sprayed like a champ. Compared to some others "nitrous cams" not as good.
