Best NOS Setup for Stock LS!
Old 08-08-2011, 04:19 PM
Z28Camaro34's Avatar
Default Best NOS Setup for Stock LS!
I was wondering what is the best Nitrous setup for a stock LS1, All I have on the car is headers, dual exhaust, slp lid and thats it. I just want something that'll add some hp but not damage anything.
any suggestions?
Old 08-08-2011, 04:32 PM
Graham@NitrousOutlet
Guest
Posts: n/a
What fuel system mods do you have? How much do you want to spray? Planning on an motor upgrades?
Old 08-08-2011, 09:37 PM
dnkynrbk's Avatar
You need to upgrade your fuel pump before you start spraying it. Start there.
Do you have someone to tune your car?
Are you asking what is safe to spray on a stock ls1?
Old 08-09-2011, 01:08 PM
02_camaroz28's Avatar
Whats wrong with stock injectors and pump on a small shot?
Old 08-09-2011, 04:28 PM
Chris@NitroDaves
Guest
Posts: n/a
There is nothing wrong with running the factory pump and injectors on a small shot. The OP should be able to spray up to 150hp with his current setup and if he wanted to stick to the safer side of the line hit the car with 125hp all day with no problems.
Old 08-09-2011, 04:33 PM
optiplex's Avatar
i was running a 100 shot wet on a COMPLETLY stock motor for almost ten years and never had a problem...
Old 08-09-2011, 04:40 PM
Chris@NitroDaves
Guest
Posts: n/a
Here here
Old 08-09-2011, 07:57 PM
manfred717's Avatar
I am spraying 100 shot wet with stock fueling. No problems here, car made 433whp/469wtq with ls1 intake manifold.
Old 08-09-2011, 09:48 PM
Yeah dnkynrbk said he NEEDS to upgrade his pump and i just didnt want the OP to think he HAD to have a fuel pump to safely and reliably spray a small shot on his car. I know multiple people with similar setups that have ran 40-50 bottles through there bolt on/stock cars with no problems.
Old 08-09-2011, 10:31 PM
drop top glassman's Avatar
also intersted in maybe a 75 shot for a stock lsi with long tubes3" exhaust k&n was wondering is it like a crack pipe hahah how many runs to a bottle how much to fill the bottle ? is there a way to turn it on only when you want it so it won't spray all the time at wot. car seem to spend alot of time there 1 set a tires a summer hahaha . i figure if you can why not i always hated people who had nice cars and didn't run them like they were ment to. never done a nos setup was an old schooler but time to go with the flow just want to make sure i don't get pulled by mustang witrh a cam or worse a 240z with a fart can
Old 08-10-2011, 10:12 AM
Guest
Posts: n/a
I would rather change the pump. Its less than 200$. These cars are nearly a decade old at best. Stock stuff wears out. It is just a safer option IMO.
Quick Reply: Best NOS Setup for Stock LS!
