bent driveshaft?
bent driveshaft?
recently, it seems like a pretty decent "shake" has struck the rear of my car
at around 40-45 mph, the back of the car will start to "bounce" more or less, causing the hatch to rattle and even make the shifter jump up and down pretty noticeably
does this sound like a bent driveshaft? the car also has a double adj. panhard bar, lca's/reloc. brackets, bmr springs and adj. drag shocks
any input is appreciated!
Wouldn't a tire problem be something noticeable in a speed range while a drive shaft issue would happen at a certain RPM? If the drive shaft was bent I'm sure it would vibrate worse and worse the higher rpm's you pull.
LS1Tech Sponsor
If you still have the factory torque arm, take a look at it to make sure it isn't bending on you. I have seen the oem torque arms bend approx six inches ahead of the rear, and will cause the front of the rear to angle up. This will cause a lot of vibration from the u-joints. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
