Need Part Number for EGR air tube Gaskets
Old 03-03-2004, 09:53 AM
redbandit98's Avatar
Default Need Part Number for EGR air tube Gaskets
I guess thats what they're called..the air tubes that come off the exhaust manifolds that have the damn little metal gasket that i promply destroyed upon removal as i was removing them to change my plugs. Also does oreilly carry them under a "generic" brand. Not going for cheaper just if my dealer didnt have them i could pick them up at a parts store. I have heard that these things are prone to a "ticking sound" if bent or even removed once..damn the luck.
thanks matt
Old 03-03-2004, 10:03 AM
2002SilverWS-6's Avatar
Here is the GM part number. 12553617
Old 03-03-2004, 10:28 AM
thank you
Old 03-03-2004, 11:10 AM
boomcase's Avatar
I just use Hightemp silicon, works fine.
Old 03-11-2004, 02:05 PM
Deeavi's Avatar
Pace performance sells an air/egr block-off kit with plates and gaskets. I think it is around $20
Old 03-12-2004, 12:31 AM
blk~2000~Z28's Avatar
Same here. Made my own block off plates and threw some RED High Temp RTV sealant around the opening and have had zero problems to date.
Quick Reply: Need Part Number for EGR air tube Gaskets
