Fast 90/92 install questions
I'm going to be doing a 90/92 install in a few weeks. I just need to know what gasket to use between the t/b and intake. Also what hardware do I need to install the t/b to intake. As of now I have a ls1 intake and stock t/b. I know already I need shorter valley bolts and can use stock gaskets between the intake and heads. Any info or pointers will be helpful, Thanks in advance.
Here you go! Here is the throttle body seal http://www.compperformancegroupstore...Category_Code=
and here is the stainless hardware kit http://www.compperformancegroupstore...Category_Code=
