93 Z28 rim size
Old 08-09-2011, 09:27 PM
FocusVince's Avatar
Question 93 Z28 rim size
I have a 93 Z28 and I noticed that on one side the front wheel looks larger than the rear, and the other side the back wheel looks larger. If I let go of the steering wheel when I'm driving it pulls to the right slightly. I'm not sure if they are actually different sizes but I was wondering if 93 camaros came with staggered wheel sizes. They just look staggered (and obviously installed wrong if they are).
thanks
Old 08-09-2011, 09:36 PM
pancho toco loco's Avatar
There all 16X8, same back spacing and offset. Should be 245/50/16's on all four tires. or 235/55/16 on all four
Old 08-10-2011, 06:30 PM
bigj2717's Avatar
Did you think to just look at the tire size
Old 08-10-2011, 06:43 PM
FocusVince's Avatar
I forgot to check the tires...sorry.
thank you
Old 08-11-2011, 03:21 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
They did not come staggered from the factory.
OE sizes from the factory were 215/60R16 or 235/55R16.
Old 08-11-2011, 03:57 PM
94 Camaro Z28's Avatar
If you have the "Z" rated tire option (easy way to tell is if you have the 150 mph speedo vs. 120 mph), your car should have come with 245/50 16 tires from factory.
Quick Reply: 93 Z28 rim size
