Power Steering Fitting help
Old 08-09-2011, 10:07 PM
dphc18's Avatar
Default Power Steering Fitting help
I need the fitting and small piece of tubing thats screws into the rack for the return hose to go on anyone know where to get one?
Old 08-09-2011, 10:24 PM
99C5Coupe's Avatar
I don't know where to get one but I had to clean up the threads on the lower fitting on mine because they wouldn't engage. The thread size of the lower one is 16 x 1.5 mm, the upper one is smaller. I cleaned them with a thread file available at O'Reilly or Sears in a re-threading kit by dragging the file across the threads. Worked great, threads engaged smoothly. Hope this helps you or someone else.
Old 08-10-2011, 11:06 AM
dphc18's Avatar
Anybody?
Old 08-10-2011, 05:43 PM
sjsingle1's Avatar
you can get the fitting anywhere.......and make you own line......GM does not have the complete return line available anymore
