SLP "Two out the left" vs. "dual dual" factory cat backs
Old 08-10-2011, 11:14 AM
vtirocz's Avatar
Default SLP "Two out the left" vs. "dual dual" factory cat backs
Is the over-axle pipe the same between these two catbacks? I noticed that the "dual dual" over axle pipe is crushed for clearance and I'm not sure if the TOTL is the same.
Thanks.
Old 08-10-2011, 11:34 AM
moz2801's Avatar
I have the 2otl cb and the over axle pipe is not crushed.
Old 08-10-2011, 01:47 PM
mean_greenZ's Avatar
My 2otl is dented at the bend
Old 08-10-2011, 06:12 PM
Jay-P's Avatar
It depends if it was a SLP installed cb or if you bought it aftermarket. Aftermarket will be smooth, installed will be slightly crushed/clearanced.
Old 08-11-2011, 05:47 AM
vtirocz's Avatar
My aftermarket SLP dual dual has the crushed over-axle section (same as the SLP installed). Are you saying the TOTL is different in that aftermarket is not crushed, but SLP installed is?
Thanks.
Old 08-11-2011, 10:49 AM
Jay-P's Avatar
Thanks.
Hmm all the aftermarket ones ive seen were smooth, i guess it is just luck as to wether you get a crushed one or not. :dunno:
Old 08-11-2011, 02:02 PM
hardcore4sure's Avatar
Did you buy it fro SLP or from someone who took it off there car? If it's a take off of an LT1 SS then that's why it crushed.
Old 08-20-2011, 06:25 AM
vtirocz's Avatar
One more question: If the over axle pipe on the SLP dual dual were not crushed, would there be any clearance issues? I'm considering to cut the over axle pipe, use a pipe expander to bring it back to 3" round, then reweld back together.
Any input would be appreciated!
Old 08-20-2011, 09:24 AM
Jay-P's Avatar
It will fit fine, it was more of a precautionary thing by slp.
Old 08-20-2011, 09:51 AM
studderin's Avatar
ya I run will 3 over the axle to my 2OTL
