Racing seat harnesses for stock seats??
Hey guys I have an 02 SS with stock seats and no rear seats. I wanted to know if it was possible to set up some racing harnesses for our stock seats. Is it possible? If so what kind of harnesses and where can I get them? Besides the racing seat harnesses is there anything else I need to make this work? Let me know thanks
if you want to keep the stock seats, the best thing would be to get a CG lock.
http://www.cg-lock.com/index.html
using any kind of 4/5pt without a proper seat could cause more harm then good. unless you get an H-harness, there is nothing to keep the shoulder straps from simply falling your shoulders, no matter how tight you make them.
a CG lock gives you almost all of the hold that a proper harness does, for far less money, and is safer then improperly using a harness.
Check out Angel Pads. They're made by Angelwings Tech (www.angelwingstech.com). They give you great lateral support with stock seats.
Schroth makes a deal that hooks into your lapbelt and has shoulder harness with it. Saw one at the track looks like a cool setup.
http://www.schrothracing.com/store/t...allye/rallye-4
Schroth is the only ones I've seen designed for oem seats. The clips that you add to your oem seat belts are nothing but trouble.
http://www.schrothracing.com/store/Tuning
There's a link to a Schroth
installation guide in the following thread :
https://ls1tech.com/forums/road-raci...tallation.html
