Can an LS1 crank pulley/dampner be installed too deep, or on too far? Mine seems to be on too far & causing belt alignment issues. Thanks for any advice.
Only two scenarios come to mind:
1) The wrong offset pulley which would result in a huge misalignment (~ 3/4").
2) Your setup had the friction washer between the balancer and gear and it was left off (~ 0.080").
