Recent clutch issue
Old 08-10-2011, 03:53 PM
CAPER_pride's Avatar
Default Recent clutch issue
so my car was working fine, then all of a sudden my gears start grinding a bit and are really hard to go into 1st and reverse..............so i take the cap off the hydraulic fluid, and the pedal becomes way more firm and it easily goes in and out of gears for about 2 hours worth of driving, soon as i park it and start it again, its back to the way it was....my question is, is there air getting in there somehow? and also ive been taking the cap off and on before going for drives, and it seems to be alright, so do you think i did any damage with the slight grinding that has already happened?, also really hard to go in reverse so id pump the clutch and get it in, obviously this isnt good, wondering if i did any damage....and what could be causing this to happen.
thanks alot guys.
ps: its a 2001 ss with the 5.7L
Old 08-10-2011, 05:06 PM
blk/slvr02ss's Avatar
Sounds like u got air in the line and u need to bleed the system.
Old 08-10-2011, 07:49 PM
thats what im assuming, however could it be a slave or master cylinder leaking(even tho not a drop of fluid has come out), im gonna bleed er tm when it stops raining, but could it literally be that simple.
Old 08-17-2011, 01:50 PM
how do i bleed the system without a mighty vac....i assume i need to get under the car, is there a bleeder valve thats accessable without jacking the car up???
Old 08-17-2011, 04:41 PM
HorsePOWA's Avatar
is it a stock clutch?
Old 08-18-2011, 07:57 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Just do this.
Buy:
New Clutch Kit
New Slave (GM 2002)
New Clutch Master (Tick Perf)
Bottle of DOT 3/4
Do a 2 person Bleed, you can damage new components with the Mighty Vac. I general do a gravity bleed and then 2 person deal.
Old 08-21-2011, 12:07 PM
yea its a stock clutch
