lt1 F-body swap question
I am still only researching but I have a gutted 96 Camaro I would like to put an ls3 crate engine in it but in another thread I heard that there are issues trying to make the gauges work I would like to know if there is a special way to do this or if I can take the gauges from an ls1 f-body and put them in with out to much work.
Also I will be using the ls3 pcm and wiring harness
LT1 Gauges work fine..all of them. The Wiring lines right up with little modification.
We have a thread with swaps in it..pretty much any question you have will have an answer in there..
https://ls1tech.com/forums/conversio...on-sticky.html
