Sponsored by: DashLynx
t/a door panels on a camaro. is it possible
Old 08-11-2011, 08:37 AM
Raptor_WS6's Avatar
Default t/a door panels on a camaro. is it possible
are the door panels the same
as far as shape to the door?
Old 08-11-2011, 08:44 AM
LS1Vince's Avatar
apparently you have to cut some of the clips on the bottom, or something like that. And i think i read you have to do something about the side mirror wires.
Old 08-11-2011, 07:21 PM
6898camaross's Avatar
Id like to know as well I like the t/a door panels better but I'm afraid it would look out of place
Old 08-11-2011, 07:43 PM
LS1121's Avatar
I read on a post here that you need to change the wiring for the switches in the doors. I was going to do it but it was too much of a hassle. I just changed the cloth inserts to a black pleather lol.
Old 08-11-2011, 09:36 PM
1LOMARO's Avatar
YUP... this is NOT my car.
Old 08-11-2011, 09:45 PM
SparkyJJO's Avatar
I thought the dash was somewhat different too where they fit together, but from looking at that picture it seems it lines up OK after all.
Old 08-11-2011, 09:50 PM
atrain59's Avatar
I'm planning on doing this in the winter the TA door panels are so much nicer.
Old 08-11-2011, 09:52 PM
1LOMARO's Avatar
X2 ^^^^^^
Old 08-11-2011, 10:09 PM
Raptor_WS6's Avatar
as far as the shape and the
positions of the lock inside
and the door handle are the
same correct?
Old 08-12-2011, 12:11 AM
LS1121's Avatar
yes I believe it was just the wiring that was different.
Old 08-12-2011, 12:16 AM
3.8blackmaro's Avatar
I'm surprised at how good that actually looks.
Old 08-12-2011, 03:15 AM
Captain Double Post
BOBS99SS's Avatar
yeah it looks good , i will redo my int this winter, and im gonna have the houndstooth put somewhere in them, i got a pair of nice leather ones for 50 bucks off of craigs list lol
Old 08-12-2011, 07:57 AM
Raptor_WS6's Avatar
so it was a direct swap
besides the electronics
i mean..
everything aligned perfectly?
Old 08-12-2011, 01:00 PM
McNord's Avatar
Its a pretty easy swap, there is 1 hook that you have to cut off the TA door panel to get it to fit, its easy to figure out which one it is once you hold the door panel up into position. The lines at the dash line up just fine, The door handle & lock assembly is the same & the only issue with the electric buttons is the mirror adjustment. The windows & locks plug right in. With the mirrors you will have to cut & rewire to get the TA switch to work with the camaro plug. I on the other hand redid the bezel so I could get the camaro button to work on the TA door. Some people just get the mirrors where they want them & then leave it un-plugged.
Raptor..... Don't you already have TA door panels?
Old 08-12-2011, 03:20 PM
I think I may have to look into this a bit more. Shouldn't have sold the TA panels I had.
Old 08-12-2011, 03:48 PM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Ya I like the door panels and leather seats on a T/A's way more then Camaro's but I don't like the gray power lock/window switches on them, they look cheap and I might be the only guy that see's that, but that's just me.
Old 08-13-2011, 08:29 AM
LT4vert's Avatar
I though that to, so I jus fabbed the camaro switch openings into the TA bezel like McNord did with the mirror switch. For the TA mirror switch I jus taped off the little triangles and painted it satin black to match the switches.
Old 08-13-2011, 08:53 AM
^ now thats whats up.
Old 08-13-2011, 09:04 AM
SparkyJJO's Avatar
Only downside is the lock switch is sideways.
Old 08-13-2011, 09:19 AM
That's exactly what I said, I just noticed it but it sure does look better then gray.
Quick Reply: t/a door panels on a camaro. is it possible
