Cat delete pipes
Moderator
Mufflex makes decent stainless ones. I've also run
across some no-name, non-stainless ones that were
alleged to fit but the angles were wrong.
I run the Mufflex tubes and SLP "for stock cats" Y
presently, and don't plan on changing again.
Honestly probably not worth the trouble. Just buy some LT headers and a y pipe, youll see very noticeable power gains and throttle response will be better too.
If you are not running cats you need to tune the car and have the rear 02's turned off so they wont throw codes.
I had a custom setup made that looks just like the pictured setup above^^^
As far as exhaust volume goes, it made it a little bit louder. I have it going into a stock cat back as well. When i got it done i noticed no difference in power. However i put in a cutout right behind the merge, and with a rough street tune with the cutout open i noticed a big difference in sotp feel.
I couldnt afford to do LT's/ORY at the time so i done it as a temporary setup til i could. Paired with a cutout and a tune, id say its worth having. But just the pipes by themselves you probably won't notice anything but extra noise. That was the case for me anyway.
That's MISTER MODERATOR
You will pick up some power but not a ton. A tune for it will help and is always a good idea. I've had great luck with the fellars at pcmforless.
