FTI new release available at Jegs High Performance
Old 08-11-2011, 09:52 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Default FTI new release available at Jegs High Performance
FTI has now released a new line of LS converters for the budget minded crowd that need a lil converter but dont want to break the bank.
The Street Brawler series converters are a great economical aproach to the high end billet converters. The feature furnace brazed and tig welded fins, High energy carbon clutch that has the same surface area as a factory converter,precision ground hardened impellor hub,and computer balanced. This converter is an 11" model and is available in 4 different stall speeds.
SB2600LS 2600 stall
SB2800LS 2800 stall
SB3000LS 3000 stall
SB3200LS 3200 stall
These converters are also available thru Jegs high performance with a 2 day arrival time from date of order as they have them in stock. Jegs.com also carries many of our other products with more being added daily.
http://www.jegs.com/webapp/wcs/store...Id=10002&Nty=0
Or you can order direct from FTI.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
FTICONVERTERS is offline
Old 08-11-2011, 10:50 AM
AutoRoc's Avatar
How did you pull that off!?! Nice work and I am definately in the market for a 3200.
AutoRoc is offline
Old 08-12-2011, 12:42 PM
Blue85350's Avatar
this is awsomeness
Blue85350 is offline
Old 08-12-2011, 04:02 PM
LS1Tech Sponsor
They have all of our popular part numbers so if you are in a hurry for one this could be a good thing. They garuntee 2 day delivery on most everything they sell.
Greg
__________________
1-866-726-8358
FTIPerformance.com
Quick Reply: FTI new release available at Jegs High Performance
