G-body oil pan
Old 08-11-2011, 07:22 PM
Beeterolds's Avatar
Default G-body oil pan
Im sure this top has been exhausted time and time again here however using the search feature has not netted me the answer I was looking for..
Im going to install my 5.3 motor into my 1983 Cutlass supreme.. ok simple enough.. Im sure its been done a bazillion times.. Im wondering if I can get away with using the truck oil pan as long as I hack off about 3 inches so the pan is roughly flush with the filter.. Or Is there a better approach? I'm a diyer and of course I could shell out a couple C notes and get the appropriate pan but I want to save my cash for other aspects of this swap..
the truck pan looks reminiscent of the olds/chevy style rear sumper so I can't foresee any issues with clearance with the exception of the big ol' set of nuts I would have dangling under the car asking for a speed bump to kick..
Thanks guys.
Old 08-11-2011, 10:09 PM
blackedout drop ls1's Avatar
My cousin just did a GN ls swap and the conversion pan was only 150 with pick tube and windage. And what I couldnt believe was he ordered it from the local GM dealer
Old 08-11-2011, 11:51 PM
sawzall wielding director
G-Body's Avatar
You can make the truck pan work in the g-body. However, the truck pan is ~2" deep in the front section and if you are trying to set the motor in so that the crankshaft sits at the same height and angle as the factory small block, the truck pan will be sitting against the crossmember before the front of the motor is low enough. If you are using a set of bolt on adapter plates for the motor mounts it should raise the motor enough to clear the k-member.
If you know someone who can weld aluminum, shortening the pan is fairly easy.
Old 08-12-2011, 12:06 AM
the_merv's Avatar
GM Muscle Car Pan Kit..like mentioned above..$155 at the Dealership and comes with everything.
Part number 19212593
Here is pics of it on my Engine..
Old 08-12-2011, 10:12 AM
spacemanspif's Avatar
Depending on the motor mounts the muscle car pan may sit below the crossmember about 1/2 to full inch. I went with the autokraft pan which is a little pricey but I couldn't afford to do multiple test fits of the engine and I liked that it had the integrated fuel filter attachment.
Old 08-12-2011, 04:02 PM
Beeterolds's Avatar
I've been going back and forth with this topic in my head.. I plan on using factory SBC mounts with the side plate adapters simply because I have the parts on hand.. If the pan comes in contact with the crossmember worse comes to worse I could always elevate the mounts on the frame
Old 08-12-2011, 11:32 PM
the_merv's Avatar
I have the stock mounts and the factory clamshells like you see..no issues.
Old 08-13-2011, 01:24 AM
01cherryreds10's Avatar
Muscle car pan kit is the way to go. Finally got mine on the road today. So far no roadkill!
Old 08-13-2011, 01:38 AM
the_merv's Avatar
I've splattered one armadillo off of mine..at about 75mph..lol
Old 08-13-2011, 01:43 AM
Hah I had one of these pan come down at me at work once because I didn't start the bolt enough. Poor armadillo!
If you are good with a welder you may want to cut an inch off. Mine hangs even with the headers as does mervs so I didn't even bother. Nice piece and cheaper than a cts-v pan. You can't even get the old style cts pan, so you'll have to fight with the mounting bosses on the side
Old 08-13-2011, 01:34 PM
labelblack68's Avatar
I would shell out the 150 for the pan, instead of the time and headaches that could come from shorting the truck pan
Old 08-14-2011, 11:20 AM
Beeterolds's Avatar
This is true and something I may take into consideration.. however I have a friend who is a skilled TIG welder.. and I have a good high speed die grinder.. so ill try the truck pan worse comes to worse it goes on my scrap pile
Old 08-14-2011, 11:07 PM
G-Body's Avatar
I cut the truck pan for my brothers swap. The easiest way I found was to cut it apart with a sawzall (12" Torch blade preferred). Then put an endmill in the drillpress (yeah I really wish I had a mill) and slide the pan around the drillpress table till the edges were all milled to exactly the same height. I used the drillpress/mill to true up the edges of the bottom section that was welded back on.
Old 08-15-2011, 09:18 PM
bowtieboySS427's Avatar
That's what I'm talkin about. Love your spirit. Screw payin out 150 for a pan. Hack it, weld it and if you f it up throw it in the scrap pyle then go buy the swap pan. That's how you learn the best man. The way I see it I can screw a lot stuff up and its still cheaper than a college education. Lol although if I totalled all of my damages it would be a close one!
Old 08-15-2011, 09:19 PM
Needless to say I bought the swap pan lol
Old 08-15-2011, 09:27 PM
the_merv's Avatar
I have an extra truck pan, but I saved it as a backup for my Sierra incase I bust it.
Old 08-15-2011, 11:02 PM
G-Body's Avatar
Yeah we had 3-4 extra truck pans sitting around so it was basically free. Plus on my brothers swap (B-Body GM) there are not any GM pans that fit. The f-body and vette pans extend too far forward, the truck, musclecar, and ctsv pans all hang under the crossmember. The pans are surprisingly strong though, he drove the car with a truck pan hanging 3" below the crossmember and bottomed it several times. The pan was all scrapped up and he ended up breaking 2 mounting ears off the upper drivers side of a TH400 trans but it never cracked the pan.
Old 08-15-2011, 11:59 PM
the_merv's Avatar
Damn..lol
Old 08-16-2011, 01:25 AM
74novacustom's Avatar
I finally looked under my car with the Muscle car swap pan, i custom made my motor mounts and put the pan a half inch above the crossmember.
It hangs scary low, i havent measured yet. But with me and a passenger in it im thinking 4 inches of ground clearance or less. My car does sit low so i might think of getting better front springs to keep it stiff or build a small scraper off of the crossmember.
Old 08-16-2011, 01:29 AM
the_merv's Avatar
1/4" Flat-steel as a skidplate..set it up like the 4wd trucks.
Quick Reply: G-body oil pan
