ls1 bleeding help
Old 08-11-2011, 07:29 PM
ls1tafirehawk's Avatar
Default ls1 bleeding help
II've been bleeding now for 4 weekends straight and im sick and tired of the bullshit hydraulics in the f body's Ta's. Does any one have a known working method of bleeding the slave. I've tried gravity bleed,old fashion crack the bleeder valve,miry vac n I still don't have the right pedal engagemen/disengagement. I've heard of the jmd method but don't quite understand it, is there a video of someone using that method.any ideas is very appreciated.
Old 08-11-2011, 07:46 PM
runnin13s's Avatar
have you tried to change the master cylinder all togethe? maybe its not a bleeding issue but instead a hydraulic fluid "flow" issue/ not moving enough fluid.
Old 08-12-2011, 09:13 AM
Im bout to buy a tic adj MC in see will that work
Old 08-12-2011, 09:21 AM
Plaugher4's Avatar
I had issues with mine when I did my clutch swap. Just make sure the reservoir is full, grab the pedal with your hand and pump the absolute **** out of it.
Old 08-12-2011, 11:34 AM
SPEC-01's Avatar
Have you noticed any changes in the reservoir fluid level? I assume you would have noted leaks so the Master is the most likely cause of this issue and it can bypass fluid internally without ever visually leaking.
Old 08-12-2011, 11:49 AM
No fluid level changes. I figured if there's a leak the resvoir level will decrease but the fluid level is always full. I did the drill mode but still not the right pedal engagment
