motor build
motor build
Ok folks I'm the middle of a build and im looking for some ideas on to finish the internals. I have a GEN4 block bored out to 4.070 the crank has a 24tooth reluxor wheel. I have 317 heads with double bee hive springs. My pistons are mahle -4cc. part number L92105070F04 for personal reasons I'm going to go carbureted so my intake manifold will be edelbrock 71181 with a 800 CFM quadrajet carburetor. I also have the katech piston squirters installed in the block. This motor will be put into a 1978 Chevy Blazer mud drag truck. So now that you have an idea whatI'im talking about I have yet to purchase a cam, lifters, push rods, and rockers. Since all 4 of those parts kind of need to work nicely together.
so as you can tell its a little of a franken motor build. which makes deciding on parts a little more difficult. any advice would be helpful.
