Can anybody tell me the differance between the Ktech rod bolts and the ARP rod bolts?
Whats the differance between the $88 dollar ARP bolts and the $200 dollar ones from Katech? Im putting together a stock bottom end 6.0 with LS3 heads. Shouldnt see over 7000 RPM. What are everyones thoughts on this subject? Thanks Eric L
Can I get away without resizing the rods seeing how they are capscrew style bolts? I would rather not spend the money on resizing the stock rods if I can avoid it. Thanks, Eric L
Katech rod bolts are a direct replacement, you don't have to resize the rod with them, As far as how the katechs compare to arp's strength wise, I couldn't tell you, i email'd katech and they told me "we have not researched arp's fasteners so we do not know".
I would also like to know myself how strong the katechs are at their lower torque recommendation and if they are just as strong as the ARP's at the(katech's) lower spec
8740 180,000 yield psi 200,000 psi tensile
ARP2000 180,000 psi yield 220,000 psi tensile
Katech 260,000 yield supposedly unknown tensile
