LS1 Swapped Mustang EPS 234/246 Results!
Old 08-12-2011, 06:56 PM
itsslow98's Avatar
Default LS1 Swapped Mustang EPS 234/246 Results!
Finally after a long 6 month build I put my 1993 Mustang Coupe on the dyno at Race Proven Motorsports for a full dynotune.
Mods
2002 Ls1/T56
LS6 Intake
Stock 241 heads
Kooks 1 3/4" long tubes into 3" true duals and magnaflow tru-x muffler
SLP 25% U/D pulley
EPS 234/246 .601/.606 112+3 cam
Stock injectors
Stock untouched throttle body
Stock de-screened MAF
4.10 gears
28" tire
E.T. Street Slicks
Mcleod Twin Disk
Car made great power with the final numbers being 417/389 which are pretty stout cam only IMO. Car made 17 more HP then my CTS-V on the same dyno with the mods in my sig on motor.
Car runs and drives great and has a pretty good chop at idle. The tune definetly made driveability way better and I get very very little bucking at low RPMs. I'm happy with the car and how easily it will spin the slicks from a first gear roll. I have better suspension to throw on the rear already but it does have UCA, drag shocks, air bags in it already. Car "should" be knocking on the door of a 10 second pass since it will likely weigh in at under 2800lbs.
I will scan the dyno sheet when i get a chance. Any questions feel free to ask.
http://www.youtube.com/watch?v=SEtZT13zvAk
Attached Thumbnails LS1 Swapped Mustang EPS 234/246 Results!-mustang-dyno-sheet.jpg
Old 08-12-2011, 08:55 PM
ds98formula's Avatar
Nice numbers
Old 08-12-2011, 09:37 PM
Bowtiedford's Avatar
wow thats great
Old 08-13-2011, 01:49 PM
T.Man's Avatar
Absolutely awesome numbers! Especially through some 28" tires and 4.10's.
Sick build man. Can't wait to see it in action.
Old 08-13-2011, 03:41 PM
Brennen's01SS's Avatar
I've been wanting to see a bigger eps cam only. Definitly great numbers for cam only. I thinking of going with a larger eps cam. Looking forward to see dyno sheet
Old 08-14-2011, 10:38 PM
itsslow98's Avatar
dyno sheet attached
BTW tuner said i was just on the edge with the stock injectors and he could see the ls6 really struggling to keep up and suggested my next mod to be a FAST 90/92 and 42lb injectors. I will probably just go straight to 150 shot over the winter.
Old 08-15-2011, 07:32 AM
LS6
LS6's Avatar
Strong results for 241 heads
Old 08-15-2011, 08:19 AM
87silverbullet's Avatar
Check out Subhumanzz on here, he has the same cam I have from EPS but for me its in a 416 but he has it in a 346. Its 240/251 on a 114, I can't remember the lift but its around 630 lift.
Old 08-16-2011, 02:27 AM
jthunderz28's Avatar
wow that's impressive! nice numbers. But that big of a cam on stock injectors?
Old 08-16-2011, 02:32 AM
itsslow98's Avatar
I asked while it was on the dyno and he said they were ok but if I do anything else like a fast go to 42s. Before it even went on the dyno I asked and they said if it needs them they have 42s in stock they will throw in if need be but it didnt.
Its an 02 motor so it has 28.8s in it stock.
Old 08-16-2011, 07:17 PM
LSxPwrDZ's Avatar
Yeah at that power level you should be okay on those injectors but I bet they are pushing 95-98% duty cycle haha.
Old 08-18-2011, 02:53 PM
tboysen00's Avatar
Sick setup. When you hitting the track? Got anymore pics?
Old 08-18-2011, 11:29 PM
itsslow98's Avatar
Still have a few things to work out but will be at the track in the fall. Here are a few other pics in my build thread. I have a ton on my facebook page like 100+.
https://ls1tech.com/forums/conversio...pdate-vid.html
Old 08-19-2011, 08:53 AM
LSX Mechanic
Damian's Avatar
Power level dictates injector sizing, not the size of the cam.
42's are completely unnecessary for a stock bottom end car. An SVO 30 or 36lb injector will be plenty enough to support that power level. The internet has given everyone the general misconception that 42lb injectors are the fix to everything, and that's not the case. Too much fuel for a cam or heads/cam car. I don't use 42lb injectors until we're in the 550rwhp range.
Old 08-19-2011, 03:38 PM
itsslow98's Avatar
Thanks for your input, the tuner and shop build some if the fastest lsx cars in the country including the first 8 second c6z. If they suggest 42s, I'll take there word for it.
Old 08-19-2011, 08:50 PM
KC Henry's Avatar
Excellent numbers!
Gives me hope for my "cam only" 234/246 EPS cam set up.
Old 08-21-2011, 11:36 PM
A.R. Shale Targa's Avatar
Nice #s...Love the Calypso Green Fox
Old 08-22-2011, 04:09 PM
00pooterSS's Avatar
And they also recommended a FAST intake over better cyl heads..... Sounds a little backwards don't you think. Putting a FAST intake on poor flowing heads is like installing headers on a car with a pinched exhaust pipe.
Feel free to disagree, but I think this post sums up well how a fast intake is not worth the expense while having heads that do not flow enough to take advantage of the FAST.
https://ls1tech.com/forums/generatio...ts-inside.html
Old 08-22-2011, 09:35 PM
itsslow98's Avatar
So your claiming that because a stock auto 346 WITHOUT a cam at all didnt gain with a ported FAST 102 that someone with a large cam wont stand to gain anything as well. Get out of here. I wont do a FAST because i cant see the $1000 for the amount of power Id get(15rwhp) but your post doesnt prove anything. Even with a set of great heads, the LS6 intake is gonna choke them out as well anyways so doign heads would be somewhat of a waste as well without a FAST.
Old 08-23-2011, 11:17 AM
00pooterSS's Avatar
No i'm not claiming that at all, that is not what I said, read the way I wrote it. a fast intake is not worth the expense while having heads that do not flow enough to take advantage of the FAST.
My point was you stated your tuner recommended a FAST intake as your next step, which is backwards when the heads would give you a far larger gain than the intake for the same money. And in another post you stated you will listen to your shop/tuner because they build some of the fastest lsx cars in the country. So it seemed backwards. I agree with you that the LS6 will choke the setup, but it isn't choking it as much as the heads.
We are on the same page here dude.
Very nice car, I love those calypso notch's.
Quick Reply: LS1 Swapped Mustang EPS 234/246 Results!
