MrDrezzUp
08-12-2011, 10:42 PM
On the way to work yesterday, my car (2005 C6) starts making a loud ticking sound. :-( After determining the ticking sound was coming from the engine I had the car towed to a GM dealership. Driver head was pulled and a lifter from cylinder 3 was the culprit. Looks like the roller portion of the lifter seized? That particular cam lobe is now scarred and the GM tech has advised the cam should be replaced.
If I can get this car running again, I will most likely be parting ways with it. Now that I need to buy a new cam I am thinking it makes sense to go with a perfect-street-manner cam to ease the burden of trying to trade-in / sell a modified car?
Considering the engine details below (and the desire for perfect street manners) would anyone be able to provide some insight as to what sort of cam I should be ordering? Or perhaps suggest a vendor I should call to get this sorted out? With the car in the shop (and me in a rental) I am really hoping to get this sorted out in a short period of time. :-)
Engine details:
LS3 Aluminum, 418 CI, 6 Bolt Main (ARP studs), 9.240" block deck height, 4.080" bore, 11.87 SCR, 8.52 DCR
Wiseco 2618 forged flat-Top pistons, 4.078", -0.005 piston to block deck height, -4cc valve reliefs
Total Seal AP Advanced Profiling steel-top & napier 2nd ring set
Callies CompStar forged crank, 4.00" stroke
Callies CompStar forged Connecting H beam Rods, 6.125" length, 2.100" crank pin, .927" wrist pin, ARP 2000 Rod Bolts).
L92 heads, milled 0.030, 65 CC chamber
LS3 GM MLS 0.051" gasket, bore diameter 4.100"
Comp 921 spring kit
Comp Cam 230 XFI (.612) / 234 XER (.598), 117 LSA
Ported LS3 intake
Manley hardened 7.375" pushrods
Clevite "H" series race rod and main bearings
Durabond cam bearings
PowerBond underdrive pulley
LG Pro Longtube headers (hi-flow cats)
Corsa Xtreme catback
DTE Stage 1, 4.10 rear diff
Vararam CAI
NGK TR6 (0.035 gap) spark plugs
Engine details:
Comp 921 spring kit
Ported LS3 intake
Vararam CAI
