new pb and lifted a head 9.03@146 updated with pics
car went 9.03@146 lifting a head and letting out early. car was on a pass. it went 5.8@124 in the 1/8th. the car usually picks up 30mph on the big end, so it was going to put down a good mph.
25psi 15-16* timing
80mm turbo
100 shot
meth injection
e85
no intercooler
iats were 200+
http://www.youtube.com/watch?v=btEseob4mZc
this is on number 3 and 4
block and pistons look fine.
25psi 15-16* timing
80mm turbo
100 shot
meth injection
e85
no intercooler
iats were 200+
yeh it looked to be on a good pass for sure! seems like you need to get the IATs in order to play it a bit more safe.
I'm a little surprised they are that high though with meth and E85.
damn just noticed 100 shot along with 25 psi .. wow!
i dont remember why i went with ls3s but next time thats the plan
i think the turbo is done. i think it started blowing hot air. with e85 meth and nitrous you would think iats would be good. now its time for a2w, good heads and a bigger turbo!!!
I read a lot about lifting heads on the LSX motors. How common is it to O-ring blocks or heads on these engines? Do you guys not do that because of the OEM MLS gaskets?
Also, someone made a reference to the LS9, were they talking bout LS9 heads not lifting or just using the LS9 gaskets and not lifting those?
