Can someone please point me in the right direction?
Old 08-14-2011, 06:48 AM
corpserodeo666's Avatar
Default Can someone please point me in the right direction?
Ok here is the deal. I have a set of high z 115lb injectors from FIC, I input all the information given to me into HPT. In order for me to make the car idle I have to play with the throttle to make it idle. I actually have to keep the car at about half to a quarter throttle until the car warms up. When the car warms up it idles fine, but when I give it some gas the car dies out. Also the car will only idle if I scale my injectors to 160-170lb's. Right now the car has 93 octane gas and it is a Forced Inductions motor and has a large turbo on it.
The car is extensively modded. Throws no check engine lights. As far as what else is going on I am totally clueless. I had the injectors flowed and tested and they all checked out fine. I have attached my HPT file for anyone to look at to give me an idea what I'm doing wrong.
Any help would be greatly appreciated.
