Move coolant temp sensor
I want to move the coolant temp sensor to the passenger side head and run the sensor for the gague on the drivers head this will fit the way my car is wired better. Has anyone done this or is there any issues with moving the CTS ? I can't see where this would make any difference and would clean up some wireing . Stan
Temps in the passenger side passage are a couple degrees higher. Not that it will matter much. My GM ECT sensor was in the stock location and would read 3-5 degrees lower than my Dakota digital sender. As long as you don't have cooling problems it won't be an issue.
