Engine didn't last a summer/ new build time
Well after all the BS getting this engine up and running. that i got from a member on here and was built by what i thought was a great builder(vendor on here). turned out to be nothing more than a **** poor pile of parts with a big price tag on it.
so how did i find out the engine was bad? well the car started to smoke bad on decell and then all the time. there was oil in one down pipe so i was thnking turbo. sent that in to get looked it was fine. try alot of stuff than said F--- it took the engine out did some testing found the engine had some crazy leak down going on
things wrong
crank trigger was not clocked right (old issuse)
flywheel bolt pattern is way off (old issue)
waited for 4mos and the builder still couldnt get it back together after the trigger was put back on right. (old issuse)
i ended up putting it back to together my self and after looking at the clearance and calling the builder and asking if what i found was ok. he said "its fine"( piston to bore clearances WAY off)
sorry this is me venting
on to the bright side. i took the short block up the Billy Briggs. he stayed after hours until i could get up there after work. i took the engine and heads to him. we knock a piston out real quick took some measurements and he said he couldnt belive it didnt smoke from the start. he said turn around will be pretty fast . less than 4mos LOL
whats really funny is how much power it made still being this poorly built lol
so it s getting new Diamond pistons with the same CR and hoping callies will hook it up on a crank that should of never made it pass a quality check
a better cam as well the one i have is really small
ill post pics of all the crazy junk later. i hope next time on the dyno we should see a %20 increase in power
things wrong
Well I guess I'll get this out the way and be the first to post and ask, which vendor was it? Was it a machining error or a result of hard use or users error? Or was the tune off causing the problems to start and escalate from there?
I can't quite make out if you bought a new replacement motor (i.e. shortblock or longblock complete with turbo's and all) or bought a car from someone with all this work done to it....?
**** man....Sorry about that bro. You know I was there for most of that crap too. He bought a pull out motor from a very fast well known member on here. The motor was built by a even more well known shop. We couldn't even get the motor started when we first put it in. There was 1,000 problems. Depth on the pilot bearing for the input shaft was wrong so it ate a thrust bearing. Fixed that and then it wouldn't start at all....after a lot of trouble shooting it was figured out that the crank reluctor wheel was clocked wrong so the PCM wouldn't pick up the signal. Sent the motor back and 4 months go by before its done....now this. I spent almost as much time on it as Tom did...we had good times but this is shitty. I hope that person steps up even a little bit...your name and shop build bad *** stuff but please step up and rectify this situation. I think the members name and shop shouldn't be posted quite yet.
thanks bro for the details. as far as names go they will not be posted on here.
2nd of all trying to get them to fix the crank trigger was hard as it was. let alone to fix this in a timely fashion i dont see that happen
No its not quite like that. His case seems to literally be the only one. Right here right now Isn't the place to do it as said. Both the shop and the seller of the engine are very well known and should have a chance to talk to Tom about this...if not it can go in the seller feed back if he wants.
LS1Tech Sponsor
Wow, I hate reading of the problems you're going through. You know everyone on here that reads this is extremely curious as to who this is, me included. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The car was too fast for the track with a junk 364cid engine. My car has no cage in it. And I'm putting a better cam in as well. Old one was small as hell 220 dur @ .050 and only 590 lift with a 116lsa. ill be happy with this engine.
On the other side of my life. I'm redoing a lot in my house. I have a baby girl do in Dec. And I'm trying to get my Duramax tuned which is also a PITA right now. So money is all over the place. Kind of hard putting anything to the car right now
But the only thing worst than letting a car sit. Is letting it set all apart. So its got to be fixed
Guess it would be kinda hard to strap in a car seat with a cage, I didn't realize you guys were expecting, congrats! Haven't talked to too many people back home lately but will be up for Richie's wedding so get that bitch back on the road!
I helped tom with building the motor and tuning of the car. We had nothing but problems with that vendor from the beginning. When we went to pick up the motor parts after 4months of them doing NOTHING, we found the parts were just astern all over there shop in plastic tubs mixed in with each other. After going threw all the parts we found out that we were missing a piston. So after we got everything home we cleaned every part before assembly. (1 HR per piston and rod). Then assembly, we then measured everything before and during assembly. We found some things we were unsure of and as tom said he called the vendor. That vendor said it would be just fine. (Complete BS). Basically this build was doomed from the beginning. Since tom was not a high paying comple race car build the vendor didn't care and just basically said F**k you. Can't wait to see what a real motor build from a Badass and caring builder will yield.
