who sprays a 200 on #7 plugs
Old 08-14-2011, 05:20 PM
adrynalinjunkie's Avatar
Default who sprays a 200 on #7 plugs
I am wondering if I can get away with #7 heat range ngks if I pull 10* timing and run c16 in the stand alone.
Anybody run #7s for a 200 shot?
Old 08-14-2011, 09:22 PM
Cape T/A's Avatar
I ran my BR7EFS ngks for a year on a 200 shot with no issues on 93 octane, I'm not sure on the timing in the car.
Old 08-14-2011, 09:55 PM
DietCoke's Avatar
I don't have to pull ANY timing (18*) with c16 and br7efs on a .078(200) jet. YOUR RESULTS may vary.
Old 08-15-2011, 09:00 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Why would you want to "get away with it" on nitrous?
The 7's usually work well, I just want to make sure you realize you want to stay on the conservative side with things on a street car.
Old 08-15-2011, 06:40 PM
00rcsb's Avatar
I have ran the br7's gapped to a .028 with 93 octane and a .076 nitrous pill. No problem. But every setup is different imo.
Old 08-15-2011, 06:50 PM
Mine are gapped at .034" what would be the advantage to. 028" gap?
Old 08-15-2011, 06:58 PM
kidcamaro98's Avatar
also wondering this as I am in the same boat.
Old 08-15-2011, 07:06 PM
00rcsb's Avatar
I read my plugs and I had to close the gap some because I was getting alot of spark blow out. Here is one example. I did it to clean up my tune.
Listen at the end of the video. You can also look under the vehicle and see it too.
http://www.youtube.com/watch?v=CRl8S...el_video_title
Here is it at a different track with the plugs smaller gap and I only had to drop down a pill size on the fuel side.
http://www.youtube.com/watch?v=c7lSL...feature=relmfu
Old 08-15-2011, 10:13 PM
Nitro Dave's Nitrous Outlet's Avatar
What does your motor consist of? What compression ratio?
Dave
Old 08-16-2011, 07:56 AM
NXZ28's Avatar
I sprayed my 346, cam-only car, with a 200 rwhp shot at 22 degrees timing using 93 octane for a season. No issues ever. Well, I did break the ring gear in my 12 bolt and killed the tranny at the end of the season.
Old 08-17-2011, 12:40 PM
ShiznityZ28's Avatar
Originally Posted by DietCoke
I don't have to pull ANY timing (28*) with c16 and br7efs on a .078(200) jet. YOUR RESULTS may vary.
Best advice ever....
Old 08-17-2011, 04:46 PM
00rcsb's Avatar
Dave
me? I am an 2006 lq4 6.0 with nothing but a 227/227 lsl cam with full exhaust and tune. Whatever stock is with 317's.
Old 08-18-2011, 07:05 AM
lower_the_dynamite's Avatar
I do. 346-Cam-200 Shot-BR7EF's Gapped at .32
Old 08-18-2011, 07:39 AM
bjamick's Avatar
Are any of you guys spraying with a nozzle, or are most of you using plates now? I'm on the edge of if I want to spray that much with a nozzle. Need another fuel pump anyways.
Old 08-18-2011, 09:34 AM
Guest
Posts: n/a
Most spraying above 150 are going to be using plates.
Old 08-20-2011, 08:41 PM
Custm2500's #1 Fan
silver-mod-o's Avatar
Or direct port
Old 08-22-2011, 10:31 PM
Martin718's Avatar
Im on 12 degrees of timing on a r-10 plug spraying 250 on c-16
Prob a little to easy on it huh?
Old 08-23-2011, 01:37 AM
There sure are alot of guys not pulling much time.
I just read in this months Super Chevy where they build this 454 LS and make a bunch of power. Then they throw a 200 shot at it off the rail and only PULL 6 degrees
Old 08-25-2011, 09:24 PM
Cape T/A's Avatar
now that I think of it, I believe I have 8* pulled on my nitrous tune.
Old 08-30-2011, 11:17 PM
BADBOYZ28's Avatar
I think its about time I upgraded to the 7's, I've been using the tr6's on my 200 shot. Thankfully never had any issues.
Quick Reply: who sprays a 200 on #7 plugs
