NOS mini controller wiring ?
I have the NOS 15974 mini controller. The controller has two heavy gauge wires to use for both stages to the solenoids. The diagram shows to wire them straight to the solenoids without any relays between the controller and the noids. The only power source to the controller is a small gauge white wire for the coming from the main switch.
Can I put relays between the controller and the solenoids? I don't see How that one small wire can support the current for the solenoids. This is the wiring diagram.
http://www.jegs.com/InstallationInst.../741-15974.pdf
I am trying to hookup a 15974 NOS progressive controller to an MSD 8625 Timing Twister for my stage 1 retard. Love the diagram in the post above
It is my understanding the yellow ch1 output control wire outputs a ground signal. Would this be the trigger I would use for the MSD retard? Since it is a ground output I assume I would use a relay to "convert" to a +12V signal?
Thanks
Mark
Thanks
Mark
Thanks
Mark
Thanks
Mark
