How much power can it take
How much HP and how much torque can the stock transmission in the 02 WS.6 withstand...my frend said his LT1 putting out around 400 rwhp and 373 lbs of tq is too much for his trans...and he gonnan haveta def.swap it when he does the LT4 conversion so i was wondering what the stock trans is...
i dont think the gear ratio effects it but yeah anyone got an idea or kno for a fact
the stock tranny will blow up pretty quickly after anything more than bolt-ons are done...i grenaded a trans with JUST bolt ons...they're good for stock power but anything more and they're pretty much living on borrowed time. 400 RWHP is definitely enough to kill the trans after a pretty short time.
Originally Posted by 02WS6Bird
and what kidna bolt-ons did you have to mess it up?
i had everything in my sig....the 4L65E is a little stronger (like it would probably stand up to a cammed motor) but its not worth the money unless you can get it for dealer cost (i knew someone at a pontiac dealer).
Rossler is about the best 4L60 there is but im talking top dollar stuff now...FLP is supposed to be real good too.
so what kinda numbers can the stock trannny take?
what do u intend to do with the car???? if you're gonna cruise it around the street on a regular radial and you're not doing a torque converter the LS6 stuff you were mentioning would probably take awhile to kill it... on the other hand if you want to bolt on heads and cam and make 370+ RWHP and then go to the track on a slick with a 4000 stall or something, the stock tranny isnt gonna live long at all...
BTW: your friend has an LT1 with 400 rwhp???? i wouldnt doubt that except you said he hasnt done LT4 stuff yet so im assuming he's got a blower??? if hes claiming 400 RWHP N/A with stock heads and stuff i think hes blowin some smoke up your ***..whats in his car???
Restricted User
Mine is a stock tranny with a extra deep tranny pan. I have a tranny cooler and a Trans Go shift kit set to the firmest setting. I also have a TCI 4400 stall converter. I had the line pressure ramp up with the rpm's through tuning. I will be going into my 3rd season on it running 11's and it show no signs of fatigue, and also I am pushing well over 450 rwhp... I don't expect it to last forever. When it doesn fail, I will be putting in a Rossler... JFM has run a ton of low 11 passes as well on his stocker and had no problems.
no my fren has some headwork done
he got a good amount of boltons...he dynod that so yeah he did a buncha stuff...i dont kno errything all i kno for sure tho....is SLP LM SLP Y i think he said Magnaflow HighFlowing cats....and some head work....and the dyno graph thing said 400 hp and 373 lbs of torque to the rear wheels......so yeah he prolly got suntn else that i dont kno bout.....but he dont have any forced induction or nuttin thats for sure
so what kind of numbers can the stock transmission in the SS and WS6's actually handle without getting messed up and will LAST
Mine has not given me any troubles in 77xxx miles and i run the auto x course/drag race w/slicks and drive the car like the sports car it is in general.
With the last 40xxx miles of its life having a Vig3600 stall(NO cooler) and spraying a 150RWHP shot of juice to it at the track dead hooking a 1.5 60ft for over the last year.
Yeah it wont last forever,but it is not as weak as some seem to think.
Mine is getting gone through next week(but) only because of a convertor swap(Well and it is also a good idea to freshen it up after 77xxx miles of racing).
Basically be good to it and it will be good to you. Stay away from super long smokey powerbraking and NO manual shifting,watch the fluid and sevice the filter regularly.
For what its worth. I dyno'd stock 289.9/297.7 then added Headers/custom Y-pipe/Borla/lid/GMAS/Predator/160t-sta/Convertor/Nitrous/Ngk plugs and MSD wires. No idea what i would Dyno today for sure,but around 450/500 HP/TQ.
Dave
or hell even more then 100....
say would it be able to andle very near to 500 or say...how bout boosting your car at 6-12 psi?....spraying at 150 shots....?new heads cams....what is the most this can take and keep a long life.....
i was thinking bout dropping in an LS6 motor....or figuring a way to keep it legal....with mass power gains...(i.e. headers, catted x-pipe, true duals, ram air, port and polish the heads and throttle body) ....and want to kno if the trans can take it
