LT1 Fbody to LS1 Fbody Conversion Motor Mounts
Old 08-15-2011, 08:00 AM
95mysticta's Avatar
Default LT1 Fbody to LS1 Fbody Conversion Motor Mounts
Im debating on doing a full LSx 6 Speed Swap to my LT1 6 Speed car. I was wondering if they have finally made conversion mounts so i dont have to swap k members. Im new to the LS game so this might be a repeated question but i havent found much of an answer. Any help would be much appreciated.
Thanks
Old 08-15-2011, 12:29 PM
the_merv's Avatar
Swapping the K-members and using the LS Stuff is the easiest way to go..everything will line right up where it needs to go. You will keep the stock LT1 T56 Crossmember..it works with the LS K-member..the T56 has the same mount location no matter what one it is.
Trust me when I say it's the easiest.
Old 08-16-2011, 08:07 AM
95mysticta's Avatar
Thanks ill look into it!
Quick Reply: LT1 Fbody to LS1 Fbody Conversion Motor Mounts
