putting 4 channel rear end in 3 channel car
ok my 3 channel stock rear end is toast. i found a 4 channel one. question is, if i put it on, will my abs not work? will the lights come on? will it not pass inspection? obviously i will not have tcs, but can it be hooked up?
NEED AN ANSWER ASAP OR IM GOING TO LOOSE OUT ON THIS ONE AND HAVE TO FIND ANOTHER
you can make them work but you have to drill a hole in the top of the housing and change the internal reluctor ring to the 4 chn. i would just keep looking if i were you. you should be able to find a good 3chn
yeah... its just a risk... and i need it to work. i can only afford to do this this one last time. (already had to get one new rear for this car). trouble is i need it fixed soon....
if i get this one and put it in, i believe all my brake lights will come on (hand brake, abs, and well, i dont have it, but tcs or maybe low trac or something) but if that happens, how can i get them all off? especially ABS and BRAKE
