Drag Racing Tech - lightweight fan replacement ?
View Full Version : lightweight fan replacement ?
00blacka4
08-15-2011, 04:39 PM
I was looking at replacement fans...i eventually want to go with a lightweight radiator...whats everyone using for lightweight fan setup...it feels like mines heavy as shit !!
Also what has to be changed in the tune and whatnot....PICS PLEASE
JL ws-6
08-15-2011, 05:28 PM
There's 2 small SPAL fans you can put on that will go right on the radiator, tune you just need to turn them on at a lower temp, that's all.
I'll have to look for the part # I don't remember what it is.
repo
08-15-2011, 06:46 PM
curious about this also. I have seen a single fan mounted to a flat aluminum plate. Looked like it dropped in where the dual fan goes but only one fan. I wander how it would be to make one work instead of two.
studderin
08-15-2011, 10:03 PM
I dont think your gona save wight in the rad. I posted a pic of the weight of mine in my thread I belive
Lighter fans I wnat to do also.
00blacka4
08-15-2011, 10:41 PM
those fans are retarted heavy...i work at autozone and the universal fan it called for, for a 93 LT1 which is just a circular fan was only 5.4lbs....even if you needed two of those it would be 10lbs rather than like 30 or whatever it weighs !....JL get that part number !
nmass399
08-15-2011, 11:58 PM
My fan only weighed 11 pounds man, and the radiator is light too, i don't think your gonna really lose any weight off of that to be worth it.
studderin
08-16-2011, 01:22 AM
http://i2.photobucket.com/albums/y11/studderin/IMG_4257.jpg
01 Z28 drained rad. both fans, bothe hoses, (non PS cooler)
http://i2.photobucket.com/albums/y11/studderin/IMG_4261.jpg
repo
08-16-2011, 01:26 AM
just thinking outloud here, but is one of the fans only used for air conditioning? if so the other one could be discarded if your not using ac
JL ws-6
08-16-2011, 07:51 AM
No both the fans are used on the car.
Look for a smallish SPAL fan, summit sells them, they attach to the radiator like a tranny cooler would with the pull thru plastic fastners, if ya use 2 of them like the stock setup is it will save a bunch of weight.. you just have to set the tune to turn them on pretty much all the time.
Problem, is without a shroud like the stock setup has you will only draw air thru that part of the radiator, and alot of street driving you may have a temp/cooling issue. If you run an electric water pump, and can leave that on with the fans running after a run at the track you won't have any issues, as the car will have plenty of time to cool off... on the street, I could see it possibly being inadequate.
DBN
08-17-2011, 06:42 AM
I changed from the stock C5 radiator and dual fans to an AFCO radiator and single fan. The AFCO radiator and fan weighs 15#.
JL ws-6
08-17-2011, 07:36 AM
The radiator I have here, with the fan, and the water pump on it is 19 lbs
BlackScreaminMachine
08-17-2011, 09:07 AM
I know most of the 4th gens they have a dummy fan temp guage but if N/A and street driving should be fine I would think. Only when your running FI or 100+ deg temp days in stop and go traffic. Maybe have the fans run constantly to try to keep it as cool as possible, lower thermo, and water wetter.
More just a thought but it would be cool to ditch extra weight.
