Need help from a tuner with ls1edit
Old 08-16-2011, 09:18 AM
25thhawk's Avatar
Default Need help from a tuner with ls1edit
I need someone to tune my car for new gears. I previously had it done by Eastside performance. They are no longer doing tuning. Car is a 98 camaro SS. I need to have it tuned for the new gears. Might need to eliminate some codes in the pcm, the light is on, but not sure why yet. Ill check the codes today. And also could use some part throttle tuning between idle and 2000rpm. Everything else is great. No need to put it on a dyno. I am located in Milford, Pa. So the closer the better. Thanks.
Ryan
