View Full Version : Rpm freeze
Ls1Mx-5
08-16-2011, 07:52 PM
With my carb'd ls1 and msd 6010 box, if I run both fans for long then get on it, it'll freeze at about 5000 rpm and power cuts out. What could this be about? If I keep both fans off, this doesn't happen. Do I need to run the msd and or the fans on a relay? Thanks in advance
Pop N Wood
08-16-2011, 08:16 PM
Maybe you aren't getting a full 12 volts to box when the fans are running.
How do you have things wired? What does your volt meter read with the fans on and off?
1970camaroRS
08-23-2011, 11:20 AM
There are a few threads about high RPM trouble with the MSD box being attributed to poor 12v supply. I run mine on a relay and haven't seen any problems at all. I would recommend doing that.
TXoldskool
08-23-2011, 11:23 AM
ran dedicated 10ga to mine...no issues as my efans are on there own relays.
GNCLONE
08-26-2011, 09:13 PM
could be a bad ground too.
TXoldskool
08-27-2011, 11:12 AM
the cause of many a head scratcher. :lol:
