forgot to clean flywheel/clutch before install
Old 08-16-2011, 09:36 PM
99 WS-sick's Avatar
Default forgot to clean flywheel/clutch before install
i was in such a hurry to get the car done and on the road that i forgot to spray the clutch and flywheel with brake cleaner. is there anyway to clean this without removing the tranny? will this hurt it if i dont?
Old 08-17-2011, 07:53 AM
Steve Gunn's Avatar
I would pull it apart and clean it. Clutch slip and premature failure is probable if your hands were dirty and the clutch disk was contaminated.
Old 08-17-2011, 10:40 AM
SNLPerformance's Avatar
I agree, it is not worth taking the chance of ruining it.
Old 08-17-2011, 04:22 PM
99 WS-sick's Avatar
but it wont wear off after it gets hot? its got real bad clutch chatter but iv only put 4.3 miles on it.
Old 08-18-2011, 09:09 AM
SPEC-01's Avatar
If you have an organic, Kevlar, or other similar disc material then you need to clean everything to insure proper operation, capacity, and durability. Heat is not a cure all...unfortunately!
Old 08-18-2011, 11:38 AM
The flywheel/pressure plate have a coating of oil on them to prevent rust and I have no idea how much grease you could have gotten on them during assembly. Heat will not burn it all off and not having a clean surface will cause a clutch to chatter if you've already driven on it.
Old 08-18-2011, 12:18 PM
SPEC-01's Avatar
Most clutches and flywheels have this coating but since we don't know what parts he is using it is hard to know for sure. Either way, as stated, the parts should have been cleaned initially. All that can be done now is remove them and clean them.
Old 08-18-2011, 12:49 PM
99 WS-sick's Avatar
damn...alright, i guess ill spend my birthday pulling this bastard back out today then.
pretiate it guys
Quick Reply: forgot to clean flywheel/clutch before install
