No problem but question about the radiator and coolant level.
Old 08-17-2011, 08:23 AM
02v8ta's Avatar
Default No problem but question about the radiator and coolant level.
When my car is cold I won't be able to see coolant down the radiator and the overflow is at the hot line. Doesn't matter how many times I top it off won't stay there. Is this normal ? Do I need to siphon any out of the overflow?(not going through the hassle of removing the hole thing) runs great, no leaks and now with the tune won't go past 170 at most. Not past 200 prior to the tune.
Old 08-17-2011, 08:24 AM
02v8ta's Avatar
Yes I've bleed the system a few times no air comes out. Maybe try again ?
Old 08-17-2011, 08:53 AM
qc97z's Avatar
If your radiator is not full, no matter how many times you top it off.....you're losing coolant.
Old 08-17-2011, 09:03 AM
02v8ta's Avatar
I've had small leaks before. Thought I found them all :/
Old 08-17-2011, 09:53 AM
ElkySS's Avatar
mine does the same thing. my head gaskets are leaking
Old 08-17-2011, 02:20 PM
02v8ta's Avatar
I've debated a blown head gasket. Done everything but a compression test on the cylinders. If I do it's a small *** blow. Run it till it breaks right ? I've pressure tested the cooling system, holds. Checked plugs. None of them were clean and one was gunked up. No white smoke. Hate to even think of
It now that I have it running so good.
Old 08-17-2011, 02:53 PM
shbox's Avatar
Could be that you have a leak in the hose from the radiator to the remote reservoir. Quite common. A system pressure test will not detect it.
Old 08-17-2011, 03:01 PM
02v8ta's Avatar
^ hope lives for something small. Thanks !
Quick Reply: No problem but question about the radiator and coolant level.
