Good way to build 96 lt1 up???!
Old 08-17-2011, 08:29 AM
Luke1996ta's Avatar
Default Good way to build 96 lt1 up???!
I just blew a head gasket the other day I am now taking the motor out and I wanted to put a cam in it the whole motor is stock so was wondering what would be the best route to go.
Old 08-17-2011, 08:38 AM
quik95lt1's Avatar
budget??
Old 08-17-2011, 09:11 AM
TCS OFF's Avatar
I'm pretty much in the same boat with a 96 lt1 with what appears to be a leaking headgasket.
Old 08-17-2011, 09:12 AM
Luke1996ta's Avatar
Well I don't really wanna spend a lot off money maybe a grand or less
Old 08-17-2011, 09:21 AM
Luke1996ta's Avatar
Other poeple I have talk to said to go with te lt4 hot cam
Old 08-17-2011, 09:26 AM
nomoneyz's Avatar
1k won't get you far. Probably all the bolt ons and a tune. I would do the hotcam kit if you can splurge a little more. It's not terrible and it sees good gains on stock to bolt on cars. You'll enjoy it especially if your used to a stock car.
Old 08-17-2011, 09:33 AM
Luke1996ta's Avatar
Now with the whole kit would I have to rebuild my head or would just the hotcam work with the stock heads
Old 08-17-2011, 09:50 AM
96TransAmboosted's Avatar
Hot cam was designed to work with the stock heads, You will use the lt4 springs and rockers. I would also get new pushrods as well. If your car blew a head gasket its good to have the heads checked out to make sure there not warped or cracked anywhere. For the buget you have the lt4 kit is a great way to go.
Old 08-17-2011, 10:02 AM
Luke1996ta's Avatar
Would u need a tune after doing this
Old 08-17-2011, 11:09 AM
Camaroking1996's Avatar
Auto or stick? and with a grand I would do full exhaust and CAI.
Old 08-17-2011, 11:15 AM
The should run om without a tune but I would get one anyway to get the most out of the set up. I love www.lt1pcmtuning.com Solomon is a great guy and will do a fantastic job. I use him to do all my new engine times then I go to my buddys dyno to dial it in perfect.
Quick Reply: Good way to build 96 lt1 up???!
